Old 19-May-2014, 12:27 AM   #12
WKON-DT , Real UHF Channel 44 , 224 degree magnetic compass direction will most likely be received through/at the back angle of the CM4228HD antenna.
The other weaker signal strength Tv stations to the south will not.
A Separate antenna aimed south is required to receive the south Tv stations.
No I do not recommend use a antenna rotator.
Antenna rotation Is Not Channel Surfing Friendly must wait for antenna to rotate.
Antenna rotators Are Not Recording Friendly.
Antenna rotation will be the cause of -->Domestic Situations<--about the direction the antenna is aimed.
