Old 18-May-2014, 8:14 PM   #2
A Simple Reception Situation.
The tvfool report is showing a antenna height above ground of 40 feet.
For reception of.
WTAJ-DT , Real UHF Channel 32 , (virt) virtual number (10.1) , CBS.
WATM-DT , Real UHF Channel 24 , (virt) virtual number (23.1) , ABC and Fox and This Tv.
WKBS-TV , Real UHF Channel 46 , (virt) virtual number (47.1) , Religion.
WJAC-TV , Real UHF Channel 22 , (virt) virtual number (x) , NBC and Me-Tv.
WPSU-TV , Real UHF Channel 15 , (virt) virtual number (3.1) , PBS Networks.
WHVL-LD , Real UHF Channel 27 , (virt) virtual number , (x) , MyNetwork and America One.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North , North East.
Install a , Antennas Direct , DB8e UHF Channels Antenna.
http://www.amazon.com.
Aim 1 panel at about 20 degree magnetic compass direction.
Aim the other panel at about 46 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone or tablet compass.
Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/Tripods%200703/4712.html.
Install the , ronard(4712-50-10) , 10 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , makes good antenna mast pipe , the price is low at about 10 dollars.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
As always trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to Install the Antenna at a Location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in the Directions of Reception Including Your Own Roof and Building.
