Old 18-May-2014, 6:07 PM   #40
Originally Posted by mulliganman View Post
Thank you. So, I shouldn't be concerned with any attenuation numbers above 700 MHz??? Correct?
Correct, unless you intend to run Ethernet via MoCA. MoCA frequencies extend up to 1500 MHz. But the MoCA equipment can tolerate much higher losses, so I very seriously doubt you'll find a reason to be concerned beyond an academic curiosity.
http://www.mocalliance.org/marketing...cteristics.pdf
If you don't know what MoCA is, you're probably not using it. http://forum.tvfool.com/showthread.php?t=13034
