The DB8e is designed for maximum reception ability and flexibility of use.
The DB8 has less reception ability and does not have the flexibility of use that the DB8e has.
I am doing my best to recommended antennas that will reliably receive the weak signal strength Tv stations.
You will make choice/s to install any antenna that your research and other people recommend.
