Old 18-May-2014, 12:50 AM   #39
mulliganman
Use the real channel number listed in your TV Fool Report to cross reference the frequencies listed in http://en.wikipedia.org/wiki/Televis...el_frequencies
The bottom line is that real UHF channels 14 through 51 span 470 MHz to 698 MHz. Each channel is 6 MHz wide.
Thank you. So, I shouldn't be concerned with any attenuation numbers above 700 MHz??? Correct?
mulliganman is offline   Reply With Quote
