I think you will be impressed with the number of Digital Broadcast Tv
Stations/Channels that are received.
To Prove Reception.
Run a New Continues Length of Coax from the antenna through a open door or window , direct to 1 Tv.
No parts of the antenna system amplifier connected.
The Tv Must Channel Scan for the ATSC-Digital Broadcast Tv Stations/Channels
often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air
Channels ~ in the Tv Setup Menu because the Broadcast Tv transmissions
travel through the Air from the Transmitting Antenna to the HBU44 Receiving Antenna.
DO NOT Channel Scan for Cable Tv Channels.
DO NOT Channel Scan for Analog Broadcast Tv Channels Only.
Go into the Tv Setup Menu and Select and Channel Scan for , ATSC-Digital Broadcast Tv Stations/Channels.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the HBU44 antenna at a Location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in the Directions of Reception Including Your Own , Attic , Roof , Building.
The directions of reception at your reception location are , South South West , West , North West , South East , East.
When reception has been Proved , then connect the antenna system amplifier and Rescan for ATSC-Digital Broadcast Tv Stations/Channels.
The reason for all this information is so that you do not become lost and tangled up trying to figure out if ,
'this coax is bad or that coax is bad or that splitter is bad or some other splitter is bad and etc. .'
-->All Parts<-- of the satellite system must be disconnected and removed.
Yes the coaxes of the satellite system can be used for the antenna system.
For coax that is outside.
Do Not use Cheap Design Radio Shack Coax that has the molded connectors on the ends of the coax.
Do Not use coax that has the crimp type connectors on the ends of the coax.
Yes do use coax that has the Compression Type Connectors on the ends of the coax.
Home Depot and Lowes have the coax that has the Compression Type Connectors on the ends of the coax.
Reason: Clarify information and typos.
