Thanks for the replies.
Strangely enough if I unplug the amplifier I get no signal. However, this is a cheap antenna designed for indoor tabletop use. The amplifier is the plug-in type that came with it. I was surprised I got as good of reception as i did by originally placing in the attic.
Will consider making the antenna upgrade.
Thanks again.
