Old 16-May-2014, 5:22 AM   #2
Yes start reception in the attic.
Aim a , www.antennacraft.net , HBU11K antenna at about 330 degree magnetic compass direction.
Here is how to aim antennas, www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone or tablet compass.
--->Many<---Digital Broadcast Tv Stations/Channels will be received.
A antenna system amplifier is Not required.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
For 4 Tv's connected use a 4 way splitter.
If reception situations.
Such as and not limited to Multi-Path -->Strong Multi-Path Tv Signals Bouncing All Around in the Attic due to the Strong Signal Strength Local Tv Transmissions , happen in the attic that are not resolvable with antenna aim and location adjustments in the attic then move the HBU11K antenna to above the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North West , East , North East.
Yes put the antenna in the attic.
And Yes at some time in the future it is Ok to move the HBU11K antenna to above the roof.
Last edited by teleview; 17-May-2014 at 11:17 PM. Reason: Clarify information and typos.
