Old 16-May-2014, 1:01 AM   #3
The #1 Situation Is , Multi-Path Tv Signals Bouncing All Around In The Attic.
The #2 Situation Is , The Tv Signals Are Strong Signal Strength , Makes The Multi-Path Even Worse.
The #3 Situation Is , Antenna Is Amplified , Amplified Antennas Amplify The Multi-Path Along With The Main Signal.
Amplifing Strong Multi-Path , Overloads The Tv Digital Tuner With To Many Strong Multi-Path Reflections Bouncing All Around.
The Tv's Digital Tuner Computer Is Overloaded And Can Not Correct All The Multi-Path , And Strong Strength Multi-Path.
A antenna system amplifier is Not required for reception at your location.
Avoid Multi-Path Reflections bouncing all around in the attic.
Install a , http://www.antennacraft.net.
HBU11K antenna.
Above the , attic and roof and building , in such a manner that reception is Not , Obstructed , Impeded , Blocked , in the Directions of , North West , North , North East , South South West.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building , in the directions of reception.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is install the antenna at a location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in the directions of reception including your own , attic , roof and building.
Last edited by teleview; 16-May-2014 at 8:36 AM. Reason: Clarify information and typos.
