Old 15-May-2014, 11:27 PM   #11
The DB8e has 2 reception panels that can be aimed any direction.
Because some of the , USA and Canada Tv stations are Very Weak Signal Strength and the , Very Weak Signal Strength USA and Canada Tv stations are different directions.
The 2 panels that can be aimed , will most likely need to be aim adjusted for best reception of the , USA and Canada Very Weak Signal Strength Tv Stations.
The antennas I am recommending are Maximum Reception antennas for reception of the the , USA and Canada Very Weak Signal Strength Tv Stations.
Look at the tvfool radar map , your reception location is in the middle of the map.
See the directions of the , USA and Canada Tv stations.
The tvfool radar map and and channel list shows the , Real Channels that are transmitted and received.
Tv antennas receive Real Channels.
The channel list also shows the , (virt) virtual numbers , virtual numbers are Not real channels , even if the virtual number is the same as the Real Channel.
The DB8e receives Real UHF channels 14 thru 51.
The , Y10-7-13 or Y5-7-13 or CS5 , antennas are used to receive Real VHF high band channels 7 thru 13.
