Thread: antenna advice
Old 15-May-2014, 7:21 PM   #2
tonyp063
I'd go with either the Winegard HD7694P or the Antennacraft HBU33.
Aimed at about 250 degrees magnetic, to start.
You should pick up Fox & ABC off the back, while getting maximum gain for the weaker western stations.
If you can get it higher than 15 feet, that would probably help.
tonyp063 is offline   Reply With Quote
