Thank you for the recommendation. I originally posted the reception report for my brother two years ago and someone else suggested the winegard hd 7698. How do these two antennas compare? Is the larger 7084 going to be significantly better and will one work better without a rotating motor? The antenna will be mounted on a roof about 20 feet above ground. Thanks.
