Old 15-May-2014, 6:50 AM   #3
To have any chance at seeing an ABC affiliate, you'll need an antenna with L-VHF capability.
Consider the Winegard HD7084P, Antennacraft HD1850 or Channel Master CM-5020. (I'd opt for the Winegard.)
I'd equip the antenna with an Antennas Direct PA-18 preamplifier also.
An attic install has very little chance for success, due to lower signal levels and higher interference levels. You'll no doubt need to mount outside, clear of obstructions such as trees and structures.
