Aim the , Y10-7-13 antenna at about 126 degree magnetic compass direction.
The aim of the DB8e and Y10-7-13 antennas can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
The coaxes are the same length when combining 2 Identical Antennas to increase reception.
You are not combining 2 identical antennas so the coaxes do not need to be the same length.
To reduce antenna interaction , separate antennas by 3 feet or more on the same antenna mast pipe.
Install the , Y10-7-13 below the DB8e.
Please know that the USA Tv stations are Very Weak Signal Strength , have Edge Path Obstructions =Hills /Mountains and are long distance away.
Reliable reception of USA Tv stations is a Test.
