Old 14-May-2014, 4:33 PM   #3
Install a , http://www.antennacraft.net.
HBU11 antenna , aimed at about 30 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Remove All parts of the other antenna including a external amplifier if it has a external amplifier , and also remove the power injector/power supply.
The tvfool channel list and radar report shows the , Real channel that is
received and the channel list also shows the , (virt) virtual number .
The Real channel is what is transmitted and received.
Tv antennas are selected to receive the Real Channels.
(virt) virtual numbers are Not Real Channels , even if the virtual number is the same as the real channel.
The virtual number is what is displayed on the Tv screen.
When the Tv stations changed from Analog to Digital transmission , many Tv
stations changed to a different channel , however kept the Old channel number that is now a virtual number.
Both the , ANT751 and HBU11 antennas are designed to receive Real Channels , 7 thru 51.
