Old 14-May-2014, 1:14 AM   #4
Out on the balcony install a , Antennas Direct , DB8e Antenna aim both panels at about 118 degree magnetic compass direction.
These USA Digital Broadcast Tv Stations/Channels are Very Weak Signal Strength.
WGRZ-DT , Real UHF channel 33 , NBC , Antenna Tv , Weather Nation.
WNLO-DT , Real UHF channel 32 , The CW.
WKBW-DT , Real UHF channel 38 , ABC.
WIVB-DT , Real UHF channel 39 , CBS.
This next USA Tv station is a little stronger signal strength.
WNYB-DT , Real UHF channel 26 , Religion.
These 2 Canada Digital Broadcast Tv Stations/Channels are Very Weak Signal Strength and will not be received with the DB8e antenna aimed at the USA Tv stations.
CFMT-DT , Real UHF channel 47 , OMNI 1.
CJMT-DT , Real UHF channel 40 , OMNI 2.
The rest of the Stronger Signal Strength Canada Digital Broadcast Tv Stations/Channels , Will Be Received Ok even though the DB8e antenna ios not aimed at some of them because the signal strengths are stronger.
Install a , RCA TVPRAMP1R , preamplifier.
The RCA preamp will be operated in the combined single antenna mode.
For 1 tv connected use No splitter.
http://www.hollandelectronics.com.
http://www.saveandreplay.com.
http://www.tdlcanada.ca.
http://www.ronard.com.
http://www.3starinc.com.
http://www.antennacraft.net
A 3 foot tripod antenna mount make a good antenna mount stand for a balcony.
Or can mount the DB8e antenna to the metal railing of the balcony.
Their is 1 other USA Digital Broadcast Tv Station/Channel that can be Tested for reception and it is also Very Weak Signal Strength.
WBBZ-TV , Real VHF channel 7 , Me-Tv , This Tv , Raycom Sports.
Install a , http://www.antennacraft.net.
Y10-7-13 VHF high band channels 7 thru 13 antenna.
The Y10-7-13 antenna will be installed about 3 feet below the DB8e antenna on the same mast pipe.
The RCA preamp wil be connected and operated in the separate antenna mode.
Connect the DB8e antenna to the UHF connection of the preamp.
Connect the Y10-7-13 antenna to the VHF connection of the preamp.
