Old 13-May-2014, 7:13 AM   #2
An indoor antenna is marginal at best in the situation depicted in your TV Fool report.
If I was in your situation, I'd use an Antennacraft Y5713 pointed at 218° (compass) and an Antennas Direct DB8E facing 136°. The two antennas can be combined into a common down lead by an Antennas Direct UHF/VHF combiner.
If there were more than one TV to connect, I'd place a Channel Master CM3410 between the combiner and splitter.
I'd mount outside, clear of obstructions such as trees or structures.
