Old 13-May-2014, 6:17 AM   #3
A Simple Reception Situation.
Above the Peak of the Roof in such a manner that the roof and building do not , obstruct , impede , block , reception in the directions of , North West , North , North East.
Install a , http://www.channelmasterstore.com.
CM4228HD antenna aimed at about 0 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , makes good antenna mast pipe , low cost about 10 dollars.
For 1 or 2 Tv's connected a antenna system amplifier will most likely not be required.
For 2 Tv's connected use a 2 way splitter.
For 3 or 4 Tv's connected , install a http://www.winegarddirect.com.
LNA-100 Boost antenna system amplifier before the input of the splitter.
For 3 Tv's connected use a 3 way splitter.
For 4 Tv's connected use a 4 way splitter.
Here are some places to buy the antenna and etc. .
http://www.amazon.com.
