Old 13-May-2014, 3:32 AM   #2
Some of the signals from 8 degrees are going to be difficult given the co-channel and adjacent-channel interference that's present. Still, I would try.
Consider a two antenna system. An Antennas Direct DB8E facing 8°. If the strong locals are not reliably received, try adjusting one of the antenna panels toward the NE... Not all the way necessarily, but in 5 degree steps.
The second antenna would be an Antennacraft Y5713 pointed at 338°.
Use a UHF/VHF combiner such as the Antennas Direct, http://www.antennasdirect.com/store/...Combiners.html to join the two antennas efficiently.
