Old 13-May-2014, 3:21 AM   #2
If you can get a clear view toward the west, this should be easy.
Consider the Antennas Direect SR8 or ClearStream1.
Resist the urge to use an amplifier of any sort, you have plenty of raw signal power in the air. An amplifier, external or built into the antenna may overload, leaving you with less reliable reception.
