Tv Reception
It's Ok to think creative. Does 'Top Rail Pipe' chain link fence pipe or any other pipe need to be the exact same size as antenna mast ? . The answer is No. More creative thinking , Use galvanized threaded pipe as a antenna mast and this Tee coupler # 510-606hc , bring the coax out the side coupling , and if you are concernd about the threads cutting into the coax then screw in a short plastic pipe. And for mounting 2 antennas , the same coupler turned the other way. And for mounting 2 or even 3 antennas , a 4 way galvanized pipe coupler. Thread pipe has couplers and adapters for different sizes.
