Old 9-May-2014, 8:14 PM   #4
The Current Tv Channels that are Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
The tvfool channel list columns show the Real channels that are transmitted and received and the , (virt) virtual numbers.
The Type and Kind of Tv Antenna is Selected to Receive the Real Channels.
Your location has receivable Real channels in All 3 Tv Channel Bands.
The signal strengths in the Red reception zone do not start to improve until the 50 foot antenna height above ground.
So even at 50 feet antenna height above ground a Large All Channel Antenna is required for reception.
So at less then 50 feet antenna height above ground a Large All Channel Antenna is Still Required.
Installing any antenna in the attic be it large or small will Not provide reliable reception.
Above the Peak of the Roof at About 25 feet Or More above ground so that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the direction of , South East.
Install a , http://www.antennacraft.net.
HD1850 All Channel Antenna aimed at about 171 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
10G201 preamplifier.
For 4 Tvs connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/Tripods%200703/4712.html.
Use the , ronard(4713-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast , the price is low at about 10 dollars.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the HD1850 antenna at a Location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in the Directions of Reception Including Your Own , Attic , Roof , Building.
Last edited by teleview; 11-May-2014 at 10:29 PM. Reason: Clarify information and typos.
