You are doing fine.
The CM4228HD is not a magic antenna.
The CM4228HD is a Very Directional Antenna in the forward direction and front angles to the antenna.
The CM4228HD receives Very Little , directly on the sides of the antenna , so multi-path signals bouncing around the reception area are very little received directley on the sides of the antenna.
The CM4228HD antenna has reduced reception at the back and back angles to the antenna.
The reflector rods behind the >< shaped reception elements , reflect some of signal away that is coming to the back and back angles to the antenna , such as multi-path Tv signals that are bouncing all around the area.
Moving multi-path such as and not limited to Tv signals bouncing off the Many Close and Distant Trees and Tree Leaves in the Wind is Very Bad For Reception .
The CM4228HD antenna limits reception on the sides and back/back angles to the antenna.
The Computer of the Digital Broadcast Tv Tuner Corrects Multi-Path to a Degree and then the tuner is overloaded with multi-path , and the tuner losses lock on the signal and then regains lock and then the lock is lost , and the cycle is repeated over and over.
The CM4228HD limits multi-path , the limiting of the multi-path makes it possible for the tuner to maintain lock on the signal.
The ANT751 antenna.
Because of the small size and small number of reception and reflector elements the ANT751 does not do much to limit multi-path.
Reason: Clarify information and typos.
