WXMI , Real UHF channel 19 , (virt) virtual number (17.1) FOX .
Is Strong Signal Strength , 42.8 NM(dB).
Is LOS Line Of Sight Reception.
Is 41.0 miles .
Should be no problem with reception even with 4 Tv's connected and No type or kind of amplifier.
Keep the following in mind.
All as in All , coax , connectors , couplers , splitters , and etc. , is and are suspect of being Defective.
Using amplifiers to overcome defective componets will cause more problems.
Also a antenna can be in a low signal or dead spot , try moving the antenna up or down and change location of antenna.
Also the RCA TVPRAMP1R preamp can operate in 2 different modes.
Separate UHF / VHF antennas connected.
And 1 combined UHF/VHF antenna connected.
Reason: Clarify information and typos.
