Old 7-May-2014, 6:47 AM   #2
The ANT751 antenna aimed at about 52 degrees magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Install the ANT751 antenna above the Peaks of the Roofs of the garage and house in such a manner that the roofs and buildings are not , obstructing , impeding , blocking , reception in the directions of , North East the Main Group of Tv transmitters and , North West the ION Tv transmitter.
Disconnect and Remove All amplified antennas.
Disconnect and Remove All power injectors.
Disconnect and Remove All power supplies.
Disconnect and Remove All distribution amplifiers.
Disconnect and Remove any and all types and kinds of antenna system amplifiers.
All as in All , coax , connectors , couplers , splitters , and etc.
Are Suspect of being Defective .
Replace Any and All , coax , connectors , couplers , splitters and etc. .
Use of any type or kind of antenna system amplifier to try and Ram the Tv signal through defective , coax , connectors , couplers , splitters and etc. will create more problems.
To improve reception install a bigger better antenna.
A bigger better antenna is not a substitute for correcting antenna distribution system problems.
Install a , www.antennacraft.net , HBU33 antenna.
The best way to do coax wiring is.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , www.ronard.com
Home Depot has , 10 foot 6 inch lengths , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast , the price is low at about 10 dollars.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roofs and buildings.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind on the directions of reception including your own roofs and buildings.
Last edited by teleview; 8-May-2014 at 9:17 AM. Reason: Clarify information and typos.
