Old 6-May-2014, 8:00 PM   #3
A Simple 2 Antenna Reception Situation.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North West , West , South West , South , East.
For reception of the Strong Signal Strength USA Tv stations to , South East , South , South West , West.
And The Weak Signal Strength , Canada Tv stations to , West , North West.
Install a , www.antennacraft.net , U8000 UHF antenna aimed at about 320 degree magnetic compass direction.
The Weak signal strength Canada Tv UHF Tv stations will be received at the front of the U8000 UHF antenna and the Stronger signal strength USA Tv stations will be received through back and back angles of the U8000 antenna.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Also install on the same antenna mast about 3 feet above or below the U8000 antenna , install a , Antennas Direct , C5 VHF antenna aimed at about 187 degree magnetic compass direction to receive , WBBZ-TV Real VHF high band channel 7 , (virt) virtual number (67.1) .
The C5 antenna comes with a combiner to connect the U8000 UHF antenna and the C5 VHF antenna on to 1 coax.
www.amazon.com
www.google.com
The 2 antenna combination will supply signal to , 1 , 2 , 3 , Tv's.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com .
Home Depot has 10 foot 6 inch lengths of 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe.
The price is low at about 10 dollars.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Pratice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 7-May-2014 at 9:03 AM. Reason: Clarify information and typos.
