The poor signal quality indicated by the HDHR tuner can be caused by any type of interference. If you can turn all power off to everything in the house, except the components associated with the antenna system and tuner, you may be able to determine if there is locally generated interference.
This test would not isolate multipath, FMI or any other external interference sources.
With the aid of the signal quality value, you can fine tune aim. Signal quality is more important than signal strength.
