Old 4-May-2014, 9:28 PM   #24
Paul_Aris
Originally Posted by teleview View Post
The Tv's Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channel ~ in the Tv Setup Menu because the the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna,
Some Digital Tv,s will Automatic channel scan for cable channels.
DO NOT channel scan for cable channels.
Do Not channel scan for only Analog Tv channels.
Go into the Tv Setup Menu and select and channel scan for ATSC- Digital Broadcast Tv Channels.
Yes, my Insignia only give three choices: 1. Antenna, 2. Cable, 3. Cable Satalite. Everytime I sue Antenna and it shows how many digital and how many analog signals it finds. Scanned and rescanned many times including a double scan.
My LG Smart TV does Antenna first then scans for cable, and then satalite. I get about the same results on both TVs. but I mainly working with the Insignia because it is closest to the antenna.
Paul_Aris is offline   Reply With Quote
