Old 7-Dec-2010, 6:37 PM   #6
Naomi
Hi No Static. Okay. Thanks.
Be sure to take the output of the amplified rabbit ears' power inserter and feed that into the VHF port of the UVSJ. Connect the DB2 to the UHF port and run the OUT (or combined) port to your set or converter box.
Thank you, ADtech. I will.
I'm in a valley. On the Interactive TV Coverage Browser, my home's location is always one color down from the immediate surrounding area. None of the channels I view are LOS. A rooftop antenna set at a minimum of 13 feet would provide LOS reception for me, but it is not a viable option for my current situation. For me, the signal strength of most of the channels is 35% to 50%. I'll take better performance, even if it is only a small amount.
Naomi is offline   Reply With Quote
