Old 4-May-2014, 5:21 PM   #23
The Tv's Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channel ~ in the Tv Setup Menu because the the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna,
Some Digital Tv,s will Automatic channel scan for cable channels.
DO NOT channel scan for cable channels.
Do Not channel scan for only Analog Tv channels.
Go into the Tv Setup Menu and select and channel scan for ATSC- Digital Broadcast Tv Channels.
