Old 4-May-2014, 3:09 PM   #2
Doe the TV use the stronger signal and ignore the weaker?
No. It's up to the tuner's software as to how duplicate virtual channels are handled. Most commonly, the tuner simply increments the sub-channel number of the second RF channel so that they are above the virtual channel numbers used by the first RF channel scanned into memory. Some early tuners were found to crash when they ran into duplicate virtual channel numbers.
Does this mean that it's just not in the database?
Correct. TVFool takes its data from the FCC database which rarely has virtual channel info in it. Any other data would have to be added manually which would be expected to be quite time consuming.
You can usually figure out what's on translators by checking rabbtears.info.
