Everything is connected per the instructions. The only thing that seems weird is where the transformer hangs from strain relief the cable kind of hangs against the V portion of the antenna. Not sure how to route the RG6 cable in the area. At one point I had it tied up to the main boom to route it away from the V and over toward the mast. Thought that may be a problem so I cut the zip tie. No obstructions our trees in the path the antenna is pointing until 100 feet or more.
I am getting 3 now after rescan. 17 is very bad and nothing on 8 yet.
