Weird. I installed the hbu44 on a 10 foot mast above my roof and pointed it magnetic 128 and tried 138 degrees. I get wzzm 13 strong but no nbc or cbs. I get pbs 35 1-4 and 54 1-3. What went wrong? Oh and I don't get fox 17 either. By the way the RG6 comes straight down the mast and almost straight down the house to a ground connector and then into the house. Goes in about a foot and then I have a splitter. From there about 4-6 feet to my cable wall plate. From there another cable runs it to the tv. All total maybe 50 feet of RG6 from antenna to TV 1. Just for kicks I ran all the way to the other TV which is a longer route than I need but I used existing cable that was hung from where the cable splitter is. I didn't really see any worse signal on that TV.
After removing the one splitter and inserting a barrel connector I know get 3 programmed but its in and out and never clear. 8 is still nothing and 17 slightly worse than 3. I am wondering if I need a antenna amplifier or if I should have purchased the HBU 55. Bummer.
