Old 2-May-2014, 11:16 PM   #6
--->NO Antenna Rotator and Antenna Rotation Required.<--
The Digital Broadcast Tv Stations/Channels in the Green reception zone are are Strong Signal Strength and will be received by any Tv antenna aimed in any direction.
WJAC-DT , Real UHF channel 34 , (virt) virtual number (6.1) , NBC and Me-Tv.
WWCP-DT , Real VHF high band channel 8 , (virt) virtual number 8 , FOX , And is also retransmitting WATM -ABC .
WPCW , Real UHF band channel 27 , (virt) virtual number (19.1) The CW .
WTOO-CA , Real UHF band channel 35 , is not transmitting.
KDKA-TV , Real UHF band channel 40 , (virt) virtual number (2.1) CBS .
This Tv station is Very Weak Signal Strength.
WGPT Real UHF band channel 36 , (virt) virtual number (x) PBS. At 211 degree magnetic compass direction.
To receive the easy to receive Tv stations/channels in the Green reception zone.
And to reach out for WGPT , PBS.
Above the the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South , South West , West , North West.
Install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna aimed at about 211 degree magnetic compass direction.
Buy the DB8e at.
www.amazon.com
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone compass.
To make WWCP-DT , VHF channel 8 , Rock Solid Reception and also to reach out for , WQED , Real VHF high band 13 , PBS channels.
Install a , www.antennacraft.net , Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 292 degree magnetic compass direction.
Install a , www.antennacraft.net , 10G221 preamplifier.
Connect the , DB8e UHF antenna the UHF connection of the preamp.
Connect the , Y10-7-13 antenna to the VHF connection of the preamp.
The FM radio interference trap of the preamp will be in the , in/on position.
Buy the , HFS-2D , HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
Here are chimney antenna mounts.
www.ronard.com/ychim.html
www.ronard.com
Ronard also has a 10 foot tripod antenna mount.
Do not bolt the tripod in place until a good reception location is found along the peak of the roof.
www.ronard.com/Tripods%200703/4712.html
Use the , ronard(4712-50-10) .
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that is good for antenna mast pipe.
Install the , Y10-7-13 antenna about 3 feet below the DB8e antenna on the same mast pipe.
Last edited by teleview; 3-May-2014 at 9:38 PM. Reason: Clarify information and typos.
