Agreed, I don't often suggest a rotator, but this is a case that calls for one. The 91XG or the DB8E would be a great starting point. I'd anticipate adding an Antennacraft Y10713 to the system as well.
The Y10713 would likely work well without rotation. A fixed aim point of about 280° would give you access to real CH-8, 11 & 13.
The TVPRAMP1R has separate inputs for both the UHF antenna as well as the VHF.
