Old 2-May-2014, 6:20 PM   #1
Jake V
Thumbs up General Questions on Plots and Translators
I'm curious about a few things:
1. Often times television signals can be received from two different towers. Let's say one from the north is Real Channel 14, Virtual Channel 5, and the one from the NNE for the same station is Real Channel 28, also Virtual Channel 5.
What happens if you are right in the middle and both signals are of equal strength? Doe the TV use the stronger signal and ignore the weaker?
2. For some stations in the plot (especially translators) the virtual number is not there. Does this mean that it's just not in the database? Or that the virtual station number does not apply for this channel and your tuner will only find it on the real channel and not use the virtual channel number?
Thanks for a great site. I check in regularly to learn.
Thanks!
