So what are the 3 channels that are received??
Use the Tv station Call Sign and Real Channel Number and Network to identify.
An example is , WXYZ-TV , Real channel 22 , NBC.
If the antenna is 100% working.
The coax that is New and goes from the antenna through a open door direct to 1 Tv.
The Tv Tuner is Ok and the ATSC-Digital Broadcast Tv Stations/Channels are scanned for.
Not Cable channels.
Not Analog Broadcast Tv channels.
And the loss of channels happened over night.
And now receiving 3 Tv channels , please identify so the reception situation be better evaluated.
The first picture shows a tree on the side of the Tv antenna.
The second picture shows some trees that are some distance away.
And both pictures show the antenna is not that high above the ground.
No I Do Not think you are sc*****.
My evaluation is , something is not working correctly.
And will also help to have the antenna higher.
But before installing the antenna higher.
I suspect something is wrong with the Tv.
Test reception with a different Tv.
Be sure and channel scan to the ATSC-Digital Broadcast Tv Channels.
Do the Double Rescan as recommend elsewhere in this thread.
Not Cable Tv channels.
Then Reconnect All parts of the preamplifier and scan for channels again.
Reason: Clarify information and typos.
