Old 2-May-2014, 4:44 PM   #1
TFBrubaker
Your thoughts on reception and antenna request
Hello,
I recently decided to discontinue cable TV service and install an OTA antenna and high speed internet. I plan on chimney mounting the antenna. My TVFool report is:
http://www.tvfool.com/?option=com_wr...e1c6eaf1507b48
Through an online submission, Solid Signal suggested a Winegard HD 7698P. When I researched that, I thought "that thing is huge!." So I called them and asked if there was something in a smaller footprint that might work. I'm interested in receiving WJAC (34), WWCP (8), WPCW (27), and hopefully _either_ WTAJ (CBS,29) or KDKA (CBS,25). On their advice, I purchased their HD1080x. I temporarily setup the antenna in the front yard and received WJAC (34), WWCP (8), WPCW (27) with no problems at all. But I had no luck with either CBS station.
In hind sight, I should have asked for your opinions here first. I have changed my opinion on the size of an antenna and would go with the 7698P (or another recommendation that you might have) if that will have a chance at receiving wither CBS station.
My cabling path (all RG6) will be: 50ft from the antenna into the basement, into a 2way splitter. Then 25ft to TV1, and 80ft to TV2. Would this require a preamp?
I'm going to try and attach at jpg which show my house. In the direction of WTAJ, there are trees in close proximity that are taller than the antenna will be.
Thank you in advance for recommendations!!
Tom
TFBrubaker is offline   Reply With Quote
