Disconnet and Remove All amplified antennas.
Disconnet and Remove All parts of any amplified antenna.
Disconnect and Remove the power supply/power injector.
Disconnect and Remove any and all parts of any preamplifier.
Disconnect and Remove All distribution amplifiers.
Disconnect and Remove any and all antenna system amplifiers and any and all parts of antenna system amplifiers.
Replace outside coax with New RG-6 coax that has the Compression type connectors on the ends of the coax , not the crimp type connectors.
The best way to do coax wiring after the test with a Continues length of coax is.
Have 1 splitter with the correct number of outputs to the Tv locations and run a coax from each output of the splitter to the Tv location.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
For 4 Tv's connected use a 4 way splitter.
Reason: Clarify information and typos.
