Thank you for your patience as I'm quite new at all this. I now know the difference between a booster and a power supply! You mentioned signal blocking materials. My entire home is covered with aluminum siding- that would explain the poor indoor reception. Lots of tall trees in my location too. My splitter is indeed currently ahead of power supply for the antenna and that may take a bit of doing to correct as the splitter is located in a crawl space under the buidling. While I can easily access it, there's no power down there. I won't be able to get down there soon (recovering from surgery) so I'll have plenty of time to consider options. Easiest solution: eliminate the need for antenna power. Seems like the suggested antennas don't require power but I'll ask: Do the antennas you suggested not need a power supply? Will they require grounding?
