Old 2-May-2014, 7:37 AM   #4
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South East , North West , East , North East.
Install a , www.antennacraft.net , HBU11K antenna aimed at about 118 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
A antenna system amplifier is not required.
For 2 Tv's connected use a , 2 way splitter.
For 3 Tv's connected use a , 3 way splitter.
For 4 Tv's connected use a , 4 way sitter.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the HBU11K antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
To prove reception connect a , NEW Continues Length of Coax to the antenna and run the NEW Continues Length of Coax through a open door or window direct to 1 Tv.
No splitters , No couplers , No etc. .
