The majority of the signals that are receivable at your location originate from the Dallas / Fort Worth area.
The Antennacraft HD1800 suggested by telview is a valid option, it's similar to and a competitor of the Winegard HD7084 and the RCA ANT-3036. If you want to get every possible signal, I would point you to one of these antennas. Based on performance and build quality, I would choose the Winegard. Cost and availability are valid criteria for you to use if you are choosing between these options.
If you have a desire to use a slightly narrower antenna, and you don't care to receive the signal(s) that may be available now or later on real CH-2 through CH-6... Then I would suggest the Winegard HD7698P.
The choice is entirely yours.
