You're right, there is little real change in signal levels as you go up to 50'... At least on paper.
Let's just keep the option of moving the antenna, up, down or laterally, for later... If the need is proven. It's amazing what a few inches or a few feet can do for reception in many cases. But... If there are obstructions such as trees or any part of any building, then moving the antenna to avoid the obstruction(s) should be high on the list of 'possible solutions'.
