Old 2-May-2014, 3:53 AM   #2
If I recall correctly, the GE Futura has a built-in amplifier... Your predicted signal levels in the air would suggest an amplifier could be overloaded. A booster in line is going to grossly over amplify the signals and leave you with distorted and unusable signal.
A compact antenna such as the non-amplified Antennas Direct C2V or Antennacraft HBU-11 or RCA ANT-751R would be a far better match for your signal conditions. The signal power in the air is well above the minimum needed to drive a passive 2, 3 or 4-way splitter.
Even a cheap rabbit ear style antenna would be better than any amplified option I can think of.
At least try removing the booster, completely.
