Old 2-May-2014, 3:41 AM   #1
zonaman
Loose connection better reception?
Hi there:
Here’s my signal analysis.
I currently have a digital tv and a non digital tv, on a converter, sharing a signal from a roof mount GE Futura antenna, facing roughly northeast. The set on the converter is using a booster. Here’s where it gets weird: If I screw the cable into the digital set all the way the reception on both sets disappears. If I just place the coaxial fitting on the digital set without screwing it in I get fairly good reception on both sets. If I eliminate the set on the converter, I can screw the cable into the digital tv and reception is very good. That drives me nuts. Why does this occur?
The biggest reception problems I have are pixilation and breakup and “no signal”
At any rate, I’m about to eliminate the set on the converter box and I will have 2 digital HD sets sharing the above described antenna. What would be the best set up for me in this new situation?
Thank you.
zonaman is offline   Reply With Quote
