Old 2-May-2014, 3:29 AM   #8
ljkdhall
Thanks for input (from everyone so far). Hadn't considered FM interference. It is true, there is a 100,000 watt tower (96.9FM) approximately 3.5 miles north and slightly west of my house. FM signal is from the opposite direction from where I am pointing my antenna, but I suppose that many watts that close could be a significant factor. I will see if I can pick up either an FM trap or amplifier with built-in trap. (or both, if you guys think that's what it will take)
I suppose the first thing would be to see how the signal is without an amp at all, then maybe no amp but an FM trap, then, if needed, amp and trap.
Really appreciate all of the suggestions, I will work through them and let you know what I find out.
Only problem is this weekend is already pretty full, so I probably won't have a chance to figure this all out and let you know until sometime next week.
Until then, thanks so much for the help. I'll be in touch!
Larry
ljkdhall is offline   Reply With Quote
