When I run an FM fool report for your ZIP code, I see several very strong FM signals present. You may benefit from the addition of an FM trap between the antenna and the rest of the system.
The LNA-200 is known to lack shielding that's needed to keep out strong local signals such as FM radio. I'd consider replacing it with an RCA TVPRAMP1R, which has a built-in FM trap.
You can use the built-in trap and an external trap such as the Radio Shack 15-024 if the FM signal is extremely powerful. The HD8200U is going to add to the problem of FMI (Fm interference) because it covers the FM band well. If pointed at an FM station, you can expect the 8200 to deliver quite a bit of power to the rest of your system. (But use of one or more FM traps can knock the FM signal power down to a tolerable level.)
