Old 1-May-2014, 6:46 AM   #11
Above the Peak of the Roof , in the clear , so that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North West and East .
Install a , DB8e UHF channels 14 thru 51 antenna.
Aim one panel at about 347 magnetic compas direction.
Aim the other panel at about 90 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Install a , www.antennacraft.net , Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 347 degree magnetic compass direction.
Install a , www.antennacraft.net , 10G221 preamp.
Connect the DB8e UHF antenna to the UHF connection of the preamp.
Connect the Y10-7-13 VHF antenna to the VHF connection of the preamp.
The FM interference trap of the preamp will be in the , in/on position.
Buy the , HFS-2D , HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com
www.ronard.com/909911.html
Install the , ronard(911) , 5 foot tripod antenna mount.
www.ronard.com/Tripods%200703/4712.html
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
www.ronard.com/ychim.html
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception in the directions of reception including the roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install to install the antennas at a location that has therapy amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building in the directions of reception.
