Old 1-May-2014, 1:24 AM   #1
ljkdhall
Advice on improving signal
Ok, here is my TvFool profile:
http://www.tvfool.com/?option=com_wr...e1c6b038b081d1
What I'm TRYING to do: Get rid of satellite, use only OTA, plus internet services (Netflix, HuluPlus, etc), AND Windows Media Center for DVR functions.
What I have:
1. Winegard HD8200U (because I still want to get Ames Channel 5, which is still a low-VHF station.) Mounted on pole attached to my ranch style house, approximately 16 feet off the ground, but only clearing the roof-line by maybe 4 feet.
2. Winegard LNA-200 antenna booster
3. All new quad shield RG-9 (approx 25 feet from antenna to the...(see next line)
4. HD Homerun Dual ATSC.
5. Approx 25 feet RG-9 to PC by TV in living room.
What works, what doesn't.
1. If cable is hooked up directly to my LG 47 inch TV, everything is awesome, all the channels I want come in nice and clear with no breakup or other issues.
2. If I am using my Windows Media Center PC (running from the Silicon Dust HD Homerun Dual ATSC), channels 5.1 and 5.2 work sometimes, but break-up somewhat just enough to be annoying. Channels 19.1 and 19.2 don't work at all.
So...what do I do to make the Media Center PC work for DVR recording and for direct watching? Different TV tuner? Do I need a higher mast for the antenna? Something else?
I'm open for any suggestions, and you guys seem pretty darn smart from everything I've read in your forum!
Thanks in advance for any help you can provide!
Larry
ljkdhall is offline   Reply With Quote
