Thanks for the version info.
You need a signal path to the east. If you are not on an outside unit or if the exterior is metal or stucco construction, your odds are very poor as the signal won't penetrate much, if at all. You can try putting the antenna near one of the windows and angle it as eastward as you can manage and see if you have much luck.
